GCM RokCountry Machined Bumpers
Generis
Crawling Around
Introducing the GCM RokCountry Bumpers.
RokCountry Bumpers are machined from Solid Delrin, and have anodized hard aluminum tow hoops included in the set. These fit a large variety of bodies, hard and lexan, and allow for multiple mounting positions, as well as the ease of adding bush bars or lighting by easy drilling.
Take a look at some of the setups below using the RokCountry bumpers:
GCM RokCountry Shopping page (at bottom)
Bumpers are offered with and without the winch Mount recess. Please see product pages for more information and pricing.
Bumper mounts!
We have added these simple bracket mounts to the RokCountry bumper line. These are a direct fit for the CrossCanyon chassis (and make a PERFECT JK body fit) but can be used on any scale chassis setup.
The brackets are easily reversible, and can be mounted in many hole patterns in the bumpers, so there's almost no end to the fitment or direction you set up on your frame rails. There's a good range of motion on the slots to make sure the bumpers line up on your body well.
ALL bumper brackets are BLACK anodize. We used the silver for picture clarity only.
Ive loved these thing scents the first time I saw them. Do you have mounts for a scx-10?
Can they be ordered with no tow hoops?
Will the RC4WD BullDog fit in the winch Mount recess?
I'm sure the mounts we have can be used on the scx units also. There's so many mounting positions on the back of the bumpers, and the mounts can flip around every which way, so there's going to be something that fits.
Tow hoops and the machining for them is part of the bumper, so they will all come with tow hoops.
The rc4wd winch will fit in the hole, yes. If you have a tiny spacer under the rc4wd winch then you won't have to do anything, but if nothing under it to bring it up a bit, then the rc4wd motor will hit the plastic out at the motor's end. Our milling is made for a perfect fit on the HR Warn winch minis, so that's why you need a spacer under it.
Thanks for the comments
I've been asked about these bumpers using the RC4wd winch a few times, so I thought I'd bump this up to bring the info back to life :ror: RokCountry bumpers alive and well, and with the bumper brackets, it's a direct fit for the GCM coil chassis also.
I'd be in for a couple if there was enough interest. I like the scale look and delrin is pretty durable.
I still have a brand new set in the package!! I really need to get around to installing them on the GCM Cross Canyon Chassis with the 79' Ford body.
