Thank you for the response but what I was wondering about is the gear sets from Hot Racing that offer different gear ratios. I wasn’t sure if there is a formula or something along those lines that I may be able to use. I apologize if my question doesn’t make sense or is to complicated for a thread like this. I searched the forum but wasn’t able to locate anything.
I have this same question an I have been doing some looking. As best I can tell you just have to do the math on the % difference between the gears.
For example: If the trans were 1:1 you would have a 28 tooth idler and a 52 tooth drive gear. At the 11 ish % OD/UD you have 26 tooth idler and a 54 tooth drive gear. So stock idler ( 28) vs 12% OD idler (26) is a difference of 7.2% actually. Stock drive (52) vs 12% OD drive (54) is 3.6%. 7.2% + 3.6% = 10.8% overdrive.
Keep in mind that while we say the Element has 'overdrive' in the front what it is actually doing is
under-driving the rear. Hot racing gives you the option to both under-drive the rear by even more, and also to overdrive the front a touch to get a really big total overdrive ratio.
Since the Steath-X transmission has plastic drive gears (shame shame) I am planning to do both OD the front and UD the rear for an all metal transmission.
Here is the math for all the hot racing gear sets I can find:
Overdrive (for front)
Hot Racing OD3 is 29/51 (3.5% + 2%) 5.5% vs stock
Hot Racing OD2 is 30/50 (6.7% + 3.9%) 10.6% vs stock
Underdrive (for rear)
Hot Racing UD2 24/56 (14.3% + 7.2%) 21.5% vs stock
Hot Racing UD3 25/55 (10.1% + 5.5%) 15.6% vs stock
Personally I'm planning to go with OD3 and UD3 which should net me around 20% front overdrive. That's about as far as I can justify pushing a rig that is not dedicated to competition.
First post by the way, glad to actually participate rather than lurk.
