redpeppers
I have just installed the RC4WD leaf springs kit on my G2 FJ40. Did the axle over springs placement. I’m not sure how to install the stabilizer bar in this configuration as it hits the motor when installed behind the axle and hits the servo when in front of the axle where it also needs to be attached at the same spot the steering link is. Any suggestions please? The driveshaft is also right up against the transmission with no room for any suspension movement. I tried flipping the axle, but the steering geometry is then way off. Can the transfer case be flipped? Any help would be appreciated. Thanks.
