General Rock Force 2.2 Info
dkingston
Dayton, Ohio
Kyosho Rock Force Option Parts
Dig and HS Gearset
RFW001 - Dig Linkage IMG
RFW002 - High Speed Worm Gears IMG
Front Spring Selection:
RFW003 - 1209 Soft White 2pc. (Length 64mm / Gauge 0.9) IMG
RFO13 - 1210 (Stock) Medium Black 2pc. (Length 64mm / Gauge 1.0)
RFW003 - 1211 Hard Yellow 2pc. (Length 64mm / Gauge 1.1) IMG
Rear Spring Selection:
RFW004 - 1609 Soft White 2pc. (Length 76mm / Gauge 0.9) IMG
RF014 - 1610 (Stock) Medium Black 2pc. (Length 76mm / Gauge 1.0)
RFW004 - 1611 Hard Yellow 2pc. (Length 76mm / Gauge 1.1) IMG
RFT001 - 2.2 Tires (Outside Diameter: 120mm With: 56mm)
Spur Gear
UM412 78 Tooth
UM407 82 Tooth
UM316 86 Tooth (Kit Standard)
Technical Support & Documentation
Kyosho America www.kyoshoamerica.com
Kyosho Corporation of America
20322 Valencia Circle
Lake Forest, CA 92630-8158
Main Phone: (949) 454-8854
Sales / Customer Service: (800) 716-4518
Sales Fax: (949) 454-0308
Customer Service Fax: (949) 454-8881
DOCUMENTATION (right click and Save As)
Kyosho Rock Force Exploded View
Kyosho Rock Force Manual
Kyosho Rock Force Parts List
GEAR RATIO CHART
Parts not found
Dave,
I searched the Kyosho web site tonight for the new parts but each search yielded "We did not find any results matching that criteria."
Are these new parts supposed to now be in stock?
Thanks much,
Carl
David, you're killing me. Seriously.
I still haven't received a return call from Steve yet. Is he on vacation?
Ken,
I just called him at home. He has been out of the office the last two days and will be in tomorrow. He will call you as soon as he gets your message.
Quickster,
The parts wont show up on the site immediately. Please call customer service if you want to order some directly.
(800) 716-4518
- David
Hey Ken, sorry I didn't get your message yet. I've been out of the office for two days working on a project. Now that it's complete, I'll be back in the office tomorrow as Dave mentioned, and I'll call you shortly thereafter.
David or Steve can we get a breakdown of the part numbers needed and the quantities to build two axles? I was going to look everything up in the online manual but couldn't find it uploaded on the Kyosho site yet.
I know axle kits are coming in the future but I have no patience. :ror:
Let me work on the manual and exploded parts diagram. It will need to be converted before being uploaded. Remind me in a couple days if I haven't posted it... ;-)
First post updated with links to exploded view, manual and parts list!
- David
Thanks David.
Do you know why the shaft for the worm gear is only available with the stock gears? When building the axles from parts this requires purchasing 1 set of low speed gears just for the shaft. The 2nd shaft isn't needed as it comes with the dig.
Hey David,
Another thing that's misleading on the parts list is the driveshafts (RF012 Universal joint). In the description it says 2pcs, but you only get 1 complete unit. $45 for one is a bit much.
Also on the topic of the worm gear shaft. Hopefully these will be available separately. I'd hate for a set screw to come loose, damage the shaft and I'm stuck buying the whole stock gear set to replace it.
Thanks David.
Hey David,
Both good questions. I will have to "dig" for some answers.
As for the driveshafts, I think they are referring to the universal joints as there are two to a pack. I will get an definitive answer for you.
It will probably be sometime next week at the earliest before I can get an answer due to the holidays.
- David
is kyosho america open? i have been trying to order highspeed gears for a while and no one will answer . i have left a message. any ideas?
