** Giveaway - Deuce's Wild XL 3.8" Foam Set - Giveaway** from Crawler Innovations
The giveaway winner will be chosen by a random number generator on December 13th. To enter this giveaway you must be a star holding member here on RCC. If you need information about becoming a star holding member, click this link.
Post one time to enter.
<hr style="color:#191b21; background-color:#191b21" align="center" size="1">
C.I.'s Deuce's Wild XL 3.8" Tall Single Stage Closed Cell Foam Pair
Part # CWR-3009
Part # CWR-3009
This foam fits the Axial BFG Krawler AX31042 Tire Pair & Axial Raceline AX31043 Wheel Pair.
The Deuce's Wild XL foam will fit similar height & width tires. (Pitbull Tires Rock Beast XL and the RC4WD 3.8" Mud Slingers)
This foam is for medium - high speed and light rock work.
The foam is 100% water proof.
This foam is also recommended if your rc vehicle weighs 10 pounds or greater.
This foam can be adjusted / tuned by the user by removing the O.D. ribbing with scissors to increase forward bite, however in heavy applications, the foam will wear faster.
These foams were designed for fun. They will increase traction which can lead to drive train failures. These foams do not grow @ speed and will maintain there shape on 6S Lipo.
Size comparison to a 2.2 Standard DW:
Available @
Crawler Tires, Crawler Foams, Parts and Accessories by Crawler Innovations
Thank you for entering and good luck"thumbsup"
Available @
