JDIRCC
So this problem has been happening for a while now. At first I thought it was because i was running one BEC and 2 savor 1230 sg servos. the rig would be running along fine but if you weren't wide open and were just crawling around it would glitch/stop and re-arm the esc (MMP). SO…. I removed the rear steer and tried it again on another day and noticed the problem was still there. So i thought maybe the motor itself (Tekin 35t pro) was the issue by causing it to build up resistance when crawling slowly.
NOTE: the bed is installed following the wiring diagram on the back of the pack
and is turned up to 7.4v range
Today i received my commando winch parts and rebuilt my winch. I plugged up my winch and controller (HEYOK) and started to spool up my winch line. While spooling up the winch kept glitching and was causing the same style glitchingand rearming that i have been having.
My question simply is…. Where is my issue!!!!!!:evil::evil:
EDIT: Played with it some more and now i have narrowed it down some more.
The esc glitching was the bec so i do not know what the issue was there. gonna buy a new bec and give that a try.
As far as the winch glitching goes, i have found out it only does the glitch/cut off in the one direction. i unspooled the wire in the reverse rotation and let it re rap itself back tight. so now the winch glitches in the unspool direction with no weight or force on it at all. Could this be that my nw commando winch motor is a dud and i need to get in touch with locked up rc or is my Heyok controller freaked out and i need to contact Al?
