QuesoDelDiablo
I'm crimping connectors and making my own Rx bypass cables to run the BEC direct to the servo without having cut/solder the connections to do it.
My question is this: Should I have the Rx feed grounding to the servo/BEC ground?
Holmes Hobby does it with the ground but when I studied electronics in school (I learned just enough to understand that electrical is all sparks and magic), I was led to believe that that could introduce a ground loop which may or not adversely affect the circuit.
Holmes bypass can be seen here:
https://holmeshobbies.com/electroni...ssories/holmes-hobbies-rx-bypass-adapter.html
My thought process is that what I'm trying to accomplish is the same as what I've previously done by soldering my BEC directly to the servo leads. I didn't ground the Rx feed in that method and I've never had a problem. So logically, it seems I should not need to ground the Rx feed (it's already grounded through the ESC).
I've made my first couple without grounding the Rx feed and they seem to work just fine, but am I going to run into problems down the line?
I hope I'm explaining myself clearly here..
