GT3B Hack Question and Answer Thread
Found out how to set up winch. Gerry Holm made a manual using the big manual. Broke it down for guys like me.
In case anyone needs it search: PSX Firmware for Flysky GT3B/C Manual
Now I have 4ws MOL/CRAB, DR for Dual ESC, and Winch full winch control.
You have to love the guys who think outside of the box.
Best link.... http://rc.305.cz/storage/FS-GT3BC PSX Manual.pdf
Anyone know if the rc4wd blue RX is compatible with the gt3c radio, hacked or not. I am looking to get the hack after I buy my rx/tx and would like to not have to buy a second RX if I don't have to.
Sent from my XT907 using Tapatalk 4
Hey losikid I know your a busy man but I thought I may have a better chance contacting you on here. I was just wondering if there's an eta on the gt3b I ordered 2 Mondays ago. Thanks sorry to bother you it's just for my first rc so I'm pretty anxious.
So 'm trying tthrottle heforward inder micros with the current firmware. I have gotten to work pretty well when I tried to calibrate the ECS I have to hold the throttle in Reverse to get into programming mode instead of forward like the instructions say. and also if I go into reverse and try to go forward the rear dig stays on even though I didn't turn it on. If i hit throttle forward again rear wheelS come un locked
Hello Gentlemen,
I have a modded GT3B that I updated back in 2012, works fine ever since, haven't touched it. Well I forgot a lot about it now I want to run to sidewinders in a MOA setup for a XR10 comp rig. What do I need to do, do I need a special flash to update?
Hello Gentlemen,
I have a modded GT3B that I updated back in 2012, works fine ever since, haven't touched it. Well I forgot a lot about it now I want to run two sidewinders in a MOA setup for a XR10 comp rig. What do I need to do, do I need a special flash to update?
I'm running firmware 0.4 & dual ESC's in an XR-10 with no issues (over a year now).
Search this thread for my screen name and it was last fall I did a tweaked template to program front/rear dig, proportional, etc.8)
I still need to go to version 0.6.:roll:
Hello Gentlemen,
I`m running 0.6.1 firmware and just went to the templates section on the 2nd post on the thread were is says "Dual ESC mixing templates for firmware 0.6.1".
Follow these instructions and you`ll be set.
There is also a section in troubleshooting that is on the same post and has instructions for older firmwares .
Good luck.
do i need to update my firmware? i bought my card about a year ago.
been trying to setup 4ws and following the template from the link on post 2 i dont get a lot of the options it is telling me, well i'll put some notes in here. just gonna tell you what i don't see and what i do see when i go through the menus. am i just reading things wrong. do i have old firmware? i have 0.6.1
Activate 4WS mix
Long click EPA
4
3
NOC i dont see this, i get CR0/1
Long enter
Map the 4WS mix to ST trim Buttons
Long Click REV
1
4WS
NOL don't see this, I see BNL/AR/MO/EN
100
NOR don't see this, I see RE0/1
NOO don't see this, I see OR0/1
Press and hold enter
back
Map CH 3 Button to turn crab on/off
Long click REV
C
4WS
SWI don't see this, I see MO0/1
NPV don't see this, I see PV0/1
OFF
back
Map CH3 Trim switch to control Channel 4
Long click REV
3
CH4
MOM don't see this, I see BMO/EN/NL/AR/RS
THEN I SEE RE0/1
THEN PV0/1
back
Map D/R switch to control Channel 5
Long click REV
D
CH5
THEN I SEE RE0/1
THEN PV0/1
back
