My radio came with a enter button that would not get a response when pushed. I figured since it was a momentary push button and that it would work if pushed just right, the circuit was not being completed.
So I used a small flat to pry the cover of the switch off, which holds the pink button which pushes against a small metal tab which then flexs and touches the switch contacts completing the circuit.
The metal plate in mine seem flat and so when I pushed the button, it did not flex and touch the contacts. So I took my small flat and tried to bend the two sides down and middle up on the metal tab.
I reassembled the switch and it works perfectly now. I'm going to guess since Rockhugger your switch was working and now does not, that this your problem because the switch is soldered right to the board so nothing else could have come loose causing this. Just a guess. I'm anything but a electronics wizard. Hope this helps.
