Good Time Crawlers in Wisconsin is hosting a top truck challenge.
Complete rules for GTC TTC
MUST use the same truck for all events.
If your truck breaks at any point during an event you will receive points according to how much of the event you completed.
MUST replace broken parts with the same/very similar part. Trucks are to remain the same throughout the day.
MUST use same wheels, tires, and motor for all events. May be switched out for the same part if it breaks. ie same turn motor. No gearing changes.
Truck must stay the same weight for all events. If you have added weight it can be moved around but it has to stay on the vehicle. No adding or removing weight. Slight variation is allowed for battery changes.
NO HOGS!!!
Max of 3s battery
Order of drivers to be determined randomly. Lanes for dirt drags to be determined randomly.
SLED PULL
One attempt at a pull. NO Jerking the sled!!!! Once forward progress is stopped you are done. Must have a place to attach sled to, must stay on truck for all events.
HILLCLIMB
One attempt. Once forward progress is stopped you are done.
FRAME TWISTER
One attempt. Winching is allowed. Must stay in bounds. There will be a time limit.
DIRT DRAG
Single elimination. If driver flips vehicle you may attempt to recover your truck.
OBSTACLE COURSE
Will be run G6 style with gate penalties. Hand winging is allowed with a penalty. Course will be timed.
MUD BOG
One attempt to cross. You will receive 10 seconds to "dig" once forward progress stops
Sent from my SAMSUNG-SM-G935A using Tapatalk
NO HOGS!!!
Max of 3s battery
SLED PULL
HILLCLIMB
FRAME TWISTER
DIRT DRAG
OBSTACLE COURSE
MUD BOG
