help brand new 4pks wont bind with receiver?
k20man
miami
hi guys I just got a 4pks the raceiver the comes with it is fine I put it on my xr10 it work great and I got and extra receiver brand new and cant get it to bind R603FS.
I done this before with other people 4pks so I dont think I was doing something wrong but again I whish I am doing wrong cuz each of this receiver are 89$ so I hope is not the rx or tx :lmao: so any help will be apreciate thanks "thumbsup"
hey man you need to make sure you are in the correct rx type mode. I dont recall which it is for the 603fs but see if you are in C1 or C2 mode and swith to the opposite and try again. I will look it up online real quick for you.
EDIT: Page 35 of your manual Item #2 says this:
The T4PKS transmitter can use the Futaba 2.4GHZ R603FS/FF. However, there are two
types of Futaba 2.4GHz receivers for vehicles: "C1" type and "C2" type. The R603FS
and 603FF are "C1" type. The R614FF supplied with the
4PKS set as standard is the "C2" type. Check that the setting
matches the receiver being used. For example, when using the
R614FF, the receiver type must be set to FASST-C2 and when
using an R603FS or R603FF, the receiver type must be set to
FASST-C1. If the setting is wrong, change it using the RX/SX
type select function (page 46).
thanks man I was looking at that now I guess it was my mistake I will check that in the am thanks
