HG P407 Pinion size
Big Ahso
Vancouver
Does anyone know the correct type/pitch pinion these take? 32p, 48p or some other metric size. I want to order some to try out the differences in smaller or larger pinions.
Not sure but I know you can use bruiser axles in the rear by filing two flats on axle splines. It looks like the same thing applies in the front.
It's a .6 mod by 5 mm shaft, took me forever to figure it out. Ended up using radio control info website that has the gear calculator then had to count the teeth and use calipers to measure the outside diameter of the pinion!
