Thorsteenster
Dam, I'm surprised you havn't worn your multi quote button out yet.
I posted this in electronics without a reply so I hope you can help me.
I had previously fried my rx due to reverse polarity-plugging the servo and esc incorrectly into the rx.
I bought a sidewinder esc locally (you're out of stock) and installed it, replacing a Tekin Rebel 2.
this afternoon at the park we tried to fire it up but the esc seemed to not get a signal from the rx/tx as all the lights kept blinking. there was no audible tones although this evening in the quiet I was able to hear a faint 4 tones upon turning the esc on.
since it wasnt working, and I bought the rx/tx used we tried to swap the rx with one from my friends rig (I bought the rx/tx from him used recently and it all worked fine on his sidewinder equipped rig). Plugged in his rx and with his radio were able to get it to aknowledge the signal. we then had an unrelated transmission problem so we halted work.
As of this evening I've tried everything else I can think of.
First I disconnected the rx and connected my rover rx to it. using that HItec Aggressor radio and hitec rx I tried doing the basic quick start sequence. no response from the sidewinder. I connected my rover battery to it as well. nothing. put everything back in the rover and tested the rover, which worked fine.
also tried new Hitec aggressor tx/rx, fresh out of box and the sidewinder still does the same its done all day.
all lights blink but never go out, only faint sounds, nothing else.
I would have called CC tech support but missed their hours since they're east coast. I looked on their website for FAQ and could not find anything on the sidewinder AT ALL.
this is going downhill fast...
the rig setup is as follows:
sidewinder 1/10 sport esc
GWS pico style 4 channel rx
R2 transmission
novak 55t motor "fifty-five"
towerpro mg995 steering servo
6-cell 2000mAh battery pack, fresh charge
airtronics MX-3 FM tx
where do I start looking for a possible solution?
tomorrow morning I intend to call CC tech support directly. Their website FAQ's dont help.
Can the cc bec be programmed with out having any other power source to it? Just being hooked to the castle link.
I have a question about using my LBA-10 balancer (with a 5idp charger).
I have 2 unknown lipos (one 2S, one 3S)that I got secondhand, and the balancing plugs do not match up to the ones supplied with the LBA-10.
Would it be okay to pull the wires out of the adapters connector and plug them directly into the battery connector? Obviously + to +, and then the -'s to the other wires?
Pics of the 2S:
Thanks
-Destroyer
hey jrh will you be carrying these or can you get ahold of them
Thanks
chad"thumbsup"
Yo JRH. I'm using some e-moli cells out of the v28 Milwaukee stuff but I'm having some issues charging them. I've got the newer version Hyperion 5i ac/dc and when I charge them as a lipo they only charge to 1900-2000 mah instead of the 2900 mah they are supposed to peak at. If I charge them as a lead acid they will peak up at 2800-2900mah but 75% of the time the cells blow up because the peak voltage is too high for the cells (they are supposed to peak at 4.2v per cell according to e-moli). Do you have any ideas on how I can get the 5i to peak them properly or know of a charger that will peak them properly?
When will you getting more tekin fxr esc's?
John,
I know I saw a list of chassises that the 7t will fit. I know an SW3 isn’t one of them (which I have). I’ve looked for it for so long my eyes are bleeding and I’m on information overload. Specifically the chassis I need to know about is the Edge, which I also have.
Flame me if you must, but I really tried to find it.
Also thanks for fixing my sons 7T the one he took the end cap off and couldn't get it back on, saved me a trip from AZ to California to fix it and ring his neck. Great service!
I searched this and couldn't find a answer. Will the mamba max run a Novak crawler brushless motor? Thanks for your help.
Brian
What is the best brushless motor for a super crawler? It is a pretty big crawler with maxx long arms revo shafts maxx diff etc... and using large tires too. I have a Tekin R1 Pro to power it with up to 5S lipo.
I am in the process of building a berg and have a question as this will be my first lipo setup..I'm going to be running 2 tekin 55t motors, tekin fxr esc, ccbec, 5955tg, hitec mighty mini for dig, on panther cougar tires. I'm not really concerned with max runtimes ..Hyperion EOS1210I for a charger so that I can charge the lipo as well as my 8 cell saddle pack for my ax. For the battery I was thinking any of the X-Caliber 11.1 lipos you have for sale online. Which of the 3 would you recommend. Also, I realize that there is a better Hyperion for just roughly $30 more. Since this is more than likely a one time purchase is it worth it to pony up the extra $30 and go for the big one?
Hi John,
Sent you an e-mail about a week ago with an order but no reply yet. Just trying to confirm if you got it or not (sent it to the jrh@holmeshobbies.com address) since I know some of my other past e-mails didn't make it through. Since I'm in Canada, I have to go the e-mail ordering route.
Thanks!
Pics of the 2S:
Thanks
-Destroyer
R2 transmission
yeah i hav one wut r the dimensions of the axial ax10 tranny
will the new pro handwound 540 motors work with a mamba25 esc?
thanks
