hi lux transmission options
4x4wheelier
pine
Im looking forward to get a hi lux and i want to make it scaled but the transmission is in the way of the interior. I want to keep my 3 speed so what are some options on the transmissions so i could put an interior in the car.
Dont know if anybody else tried this, but on the front face of the gearbow there is 2 holes about 3/4in apart under the spur gear. if you drill these out you can fit a motor on the front side of the tranny and get it a few inches lower. Only works with the stock gearing though...
I spaced my motor away from the plate with spare axle links drilled through all the way and cut to the correct length.
Please explain the divorced method because I am in a similar situation.
You mount the transmission under the hood of the truck, then run a driveshaft from it to a second transmission or transfer case in the center of the truck which then turns your driveshafts.
