I figured I would finally start a thread on this. I have been building one pretty much since Mr.Dlux started his, just havnt posted anything. I think this idea for an unlimited class is awesome. It's cool because almost everyone's rig is different. There are a mutitude of axles/chassis/wheel and tire combos/ect that can be combine to create a unique rig. This is the ultimate builders class.
In Erik's thread he had mentioned that losi axles would be about the right width for the mini super.. After some looking I came across a set of losi axles with an old moa conversion on them. Very minimal run time, pretty decent setup.
Of course you have to have steering front and rear.. It's a builders class why wouldn't you? A while back I picked up a losi front axle that had the XR mod done. That went up front, stock losi steering axle out back.
Chassis.. Hmm what to choose? Being that I am a DravTech team driver, and I had a spare Sudu Pro chassis sitting around, I figured that was a great choice"thumbsup" Out came the magic markers, trimmed the chassis down to what "looked right".
For the most part, this rig was built with parts that I had. Very minimal amount of money was spent to build this rig. Which is pretty cool I think. Here's some specs on the rig:
Axles
Losi axles
-Moa conversion
-XR steering and HD gears up front
-Stock losi steering and stock gears out back
RcBros steering arms
Rcbros knuckle weights (2.8oz per side.. It looked right:ror
Chassis/Suspension
DravTech Sudu Pro (cut down)
Mix and match links. I bent the lowers out of 3/16 Ti. Need to make some cf uppers to replace the current mismatch
Big bore shocks 3.5 w/cap mod(30wt oil, pink mini t's front and rear, Dlux no preload cups)
Tires/Wheels
Dlux g10 wheels (blue of course"thumbsup")
RC4WD Bully comp tires (narrowed to pizza cutters)
CI foam (special combo for the narrow tires)
Electronics
Futaba Bls157's front and rear.. Why not have a pair of $210, 513oz servos on this thing?:lmao:
Holmes 400pullers 33t (in the mail)
Castle sidewinder micro esc's
Castle bec X2
Futaba rx
Axles
Losi axles
-Moa conversion
Chassis/Suspension
Tires/Wheels
Electronics
Castle bec X2
Futaba rx
