how do i know what size deans connector
ykcor
WLA
i got a split pack ,3 on either side from the crawler store.
it has a deans connector on it .
now i need to switch to deans connectors.
question what size connectors ? and also what is the best way to switch the charger over.
thanks
newbie
as far as i know deans only has 2 sizes, the standard that comes on your RC Crawler store pack the deans part number should be 1300 and thats one male and one female and the Micro deans. they are small there is a huge diff between the two as for the charger you could make an adapter you will need one female tamyia connector and one male deans or cut the one off your charger and solder a new deans on. its really simple"thumbsup"
Deans ultra plugs. You could make a harness from tamiya to deans so you don't have to loose your ability to charge tamiya. Just hack a plug off a battery and use that and a male deans to make the adapter.
