Since I had a housing laying around and some time to kill I tried this.
Tools used were simply a dremel with a plastic cutting tool, plastic epoxy and the calipers you see later.
Parts: Stock housing and WB8 male drive shafts (will make sense later)
Stock housing
Cut the knuckle end off (try to cut it without ruining it) and learned from someone the male end of the Axial WB8 drive shafts fit extremely snug in there. I had to sand down the end just to get it started and then press fitted the shaft all the way until it got to the center portion of the housing.
I didn't use any epoxy/JB weld or anything, but the bolts to hold the link mounts will hold the driveshaft from twisting and the fact that its pressed in there it won't get pulled out.
Here is after I trimmed the end to put the knuckle mount back on.
Now to the other side. Same process. But you cut the knuckle mount off, then the space between the link mount, then to the length to get the desired width you want, I cut it all the way since I wanted the narrowest axle possible.
Picture of all the cuts I made. I cut from the outside to the center housing.
Here is it all pressed together. I did put a light layer of epoxy to ensure the knuckle mounts wouldn't move.
Here are some width measurements compared to a stock scx10 housing. The 'right' side of the housing lines up with the scx10 knuckle mount. Whereas the 'left' side is about ~1" narrower than the scx10 housing.
Hope this helps others. I'll update when I get the bearings to do the internals =)
Stock housing
