how low should u allow ur lipos to go before recharge?
+1 to both NEVER below 3.0v per cell / cutoff at 3.2v per cell or higher.
And to answer the last part a fully charged lipo should be at 4.20v per cell. If you have a charger that will monitor how much you put back into a pack (mAh) then you should not exceed 80% of the packs total capacity. So for your 1300mAh pack you should be putting back about 1040mAh.
The best thing you can do for lipo batteries is to use an ESC and charger which support lipo batts....Your esc should have a cutoff so you don't damage the cells and your charger should be lipo ready with balancing capabilities. If Your charger is for lipos and doesn't have a balancer built in, you can use an external balancer like the one I use from Losi. If your esc does not have a cutoff, you can get a warning indicator from maxamps or elsewhere to alert you of low voltage. I charge lipos at 1amp per 1000Mah (eg. 1500Mah battery= 1.5a charge) All this info you didn't ask for but I set my cutoff at 3.1v per cell and never had a problem.
Good advice! My charger has a balancer built in so I've been using that everytime. Unfortunately my sidewinder doesn't have a cut off so I'm trying to figure out how much run time I get till the packs are down to the amunt u guys suggest per cell. Thanks for the help guys.
The Sidewinder does have a cutoff.
As high as you can stand, they'll last longer if you don't discharge them as low. All of my planes are set for 10 volts (3.33v per cell). Don't run lipos in the crawler just yet.
