SeniorXJ
-Is there any way to soften up the compund on tires to make them a bit more sticky/grippy & keep that added grip??
-I was thinkin like soakin them in wd-40 or somethin along that line but am unsure of what to use to do this.
-Some research i did: Quote *Spray a layer of WD-40 & dry them with a heat gun, do it 4-5 times and it will make the tires so sticky. If you do it right WD40 will break the tire down to soften it up some.* Quote. Others mentioned using Simple Green which i dont know what that is..??
-Altho ive read that WD-40 can swell the tires if done too much & wont fit on the rims anymore. Im broke so buyin new tires is not an option when i have chemicals on hand. ;^)
Any help is appreciated!!
Thanks!!
Thanks!!
