Paul B
This has got me stumped. I had this setup in a wraith, the stock AX-3 transmitter, and the Ar-3 reciever. both original off the RTR Wraith.
I had it running in my wraith with a Castle 10A BEC set at 7v, red lead cut to the esc. Hitec HS-8954SH servo, Mamba Max Pro esc. It was flawless the whole time in there. I took the whole system out and threw it in a XR-10 to get it up and running while I wait for the parts for the punk dig etc. currently it's running on the 2 channel, no dig equipped, 2 Stock Axial 55t tin can 540 motors equipped.
The XR10 ran flawless for 2 days, then it developed a bad case of hunting/glitching. By this I mean if you leave the truck sitting idle, you can see the steering pulsing side to side, not a lot of movement, but a clear wiggle side to side. Forward is a bit choppy, but reverse is real bad, it will pulse from 1/2 throttle to dead stop to 1/2 throttle again if you hold light pressure on the reverse control. I have tried re-binding the transmitter, I have reprogramed via castle link both the BEC and the Mamba Max. Both are showing fine on the castle link interface panel. and both have been updated. I also put new batteries in the TX just to be safe, showing good power on the Tx
With the obvious out of the way, I pulled the RX out of the XR10, hooked it up to one of my aircraft RX flight packs for clean power, used a total of 3 different servos. One in the throttle, and I tried 2 different ones in the steering slot. I still have glitching and get the steering servo pulsing side to side. The only way to stop the noise/glitching is to turn down the range of travel on the TX all the way down, the control marked ST-D/R. With it turned down I get no noise, but no servo movement, by the time I turn it up enough to be usable in the truck it's glitching/hunting like mad again.
Any ideas. I know the obvious, buy a real radio, one is coming for the XR-10, but once the new one comes for that, this old AX-3 is going back into my SCX10 trail rig if possible.
