i added more lights to my lnc
sorry I forgot.
you need a 5mm drill if you are just installing the led lights.
if you use the black plastic clips then it is 6.5mm
use a piece of foam as backing to drill through the shell.
for the night crawler I put one blue on each side pointing down. front is white - red rear.
make sure you put a connector in line so can remove the body with the lights.
I used white duct tape to hold the wire in the shell.
