Ovok
I have to compliment SVT923 on his amazing write up on wheels, what a fantastic job. He mentioned that the G Made wheel will fit the trx4 and I'm partial to the G made SR03's, but I want to have them 1-2mm wider than the stock defender set-up. The SR03's have a positive 2mm offset. What do I need to do to counter act this positive offset. I plan on mounting the stock Canyon Trail tires. I read about using a narrower tamiya hex nut and extended stub axles with longer threads but I'm new to this and just not sure on what to do. Any and all help is certainly appreciated. I wanted to post a pic of the SR02 but apparently I can't post attachments, but spec's are below. Thanks
Specs:
Width: 22mm
Diameter: 48mm (1.9inch)
Offset: 2mm positive offset
Hex size: 12mm
Specs:
Width: 22mm
Hex size: 12mm
