Is it possible?... 5 position rear steer with DX5 Rugged.
Keep in mind that I'm a heli/plane/drone guy. I have a Yeti that I use to chase dogs in the neighborhood and my Capra is my first crawler and it's not crawled yet! It's a body cage on a completed chassis that has the front and rear steering servos working.
Sure, I've got the mixing programmed as I described but I may learn that it needs to be completely different whenever it is that finally try to climb over some rocks.
I'm planning to dabble in rear steer with a gspeed build I just started. I don't want to control the rear steer with the wheel. I like the 5 position rear steer that the new capra has. I can only find a 3 position option on my DX5 Rugged. Has anyone done this? Thanks!
i did it. Here is the video I watched to show me how.
https://www.youtube.com/watch?v=7zahknLJ7w0
Thank you! Not exactly what I had in mind, but probably better.
Got all my cheapo parts together (except the incision OD portal gears). Just waiting on hardcore rc steering links, and I'll have everything I need to play around with rear steer.
I had a chance to play with the incremental steering last night and really liked it.
Before with the 3 position it was either center or all the way turned, and it moved fast. I had to keep my finger on the button to keep it turned.
Now I can just click it a couple time to point the rear tire where I want it and it stays.
I haven't been running 4ws long but one of the advantages was being able to basically choose two lines at the same time. With the way I had it I hit the switch to turn, it tuned all the way and then popped back. Often when the tire returned to center it popped me off my line. Now I just click click and get on the line and stay there. I can do minimal adjustment and it stays where I put it until I want to move it.
I will have to change my style of driving. I will have to slow down when I want to do full turns to wait for the rear to steer all the way and then get back to center. BUT because it is so much more controllable, I think it will allow me to get through the gates quicker and more precise. Before I could not do last second moves with the rear steer because often it would move too much and too fast but that will no longer be a problem.
ADD: It is working well but still very slow at it. If you turn to far to get your traction things happen, you don't want to happen. It defiantly makes you think and gives you time to see what is happening, but it is does take time. I will get faster with practice.
I think on a big course where you have space to get the line you want it may not be as beneficially as it is on a tight more technical course.
As far as performance and reliability the Spektrums I have had have always been excellent. The Rugged is just a PIA to move through the screen and it is a battery hog. It get easier the more you use it.
Yes spektrum remotes are definitely battery hogs. I don't know the battery life for other aftermarket remotes though. But the factory remotes can last over a year on 4AA batteries. Spektrum is closer to a week.
Sent from my SM-N986U using Tapatalk
You can use 2s lipo or life instead of 4AA batteries. Just take the sled out and cut the wires then add a battery conector.
My Capra came with the DX3 which had a 0, 50, 100 for the rear steer assigned to a switch. I’ve been trying to replicate this with my DX5 Pro but have only been able to set up 0, 100. I can’t imagine it can’t do what the DX3 does.
The closest I have got to it is a linear setting with a 20 step which is the largest increment. Still too many switch activations to move the steering a meaningful distance. BTW, some of you guys don’t understand steps. 5 steps is not 5 steps from 0-100. It’s a very small incremental movement along the steering range. Even a step of 20 is much less than a 20% step. Something closer to 5%.
