is this 65c battery worth it?
jebster
Subscribed Member
The east coast
It all depends on what motors you're going to run and what course length you plan on riding.
If you're going to run any kind of a handwound motor, say a 35t, I think the 350mah is not going to have enough run time.
I have the 3s and 4s Elite 450mah packs, I would recommend them, highly..
I can run a 5 minute course, with some WICKED motors that love power.
Remember, the 65c just means how fast the pack can supply current (Amps) for a SHORT amount of time.
that is true. I run a pretty tame set of 45s in my rig so I thought the 350mah would be more than enough (usually run off 200 - 250 mah in a typical 6 minute run). I was thinking the 65C would give me more punch.
in my experience youll actually see more noticable power/punch going up 100mah than you will increasing C rating.
id go with the 450s
The current you can pull from pack will be the capacity x the c rating. Take a 4000 mah 25c pack. It will give you 100 amps max. Now, most xr10's pull way less than that. I had 800 mah 40c packs. I had a 450mah 25c that would get very hot and I didn't like to run it. The 800's didn't get hot.
