after seeing all the people having fun in the wet and muddy places I normally try to avoid (I hate frying electronics!) I decided I wanted to join in. I want something that can handle water and mud but still be as low maintenance as possible. i don't need a monster that can bash everywhere (not my style) so the parts list isn't going to be top end everything, just durable enough for reasonable trail runs through the back yard. I don't get a lot of time to run my rigs so I want to avoid a lot of post-run cleaning and maintenance. so the requirements are:
I'm using a ridgecrest chassis as the base. nice support and plastic so no corrosion or rust. plus I have a lot of mounting points.
axles will be stock ar60s with all stainless hardware. i'll pack them with grease. these work well and I have a lot of spare parts.
Going to use 2.2 mud basher tires, probably on plastic beadlocks. that is unless C*H*U*D gets his aluminum beadlocks out for sale!!! (check them out in his mega truck build thread)
The transmission is going to be different. I'm going to incorporate a kyosho fo-xx ve chain drive transmission. my thinking is this: bulletproof, simple (2 sprockets, 4 bearings and a chain) and I can mount the motor higher in the chassis. this transmission is also easy to clean, just a blast of wd-40 on the chain and bearings with a little shot of oil afterwards. plus, I always like something unique in my builds and I don't have a rig with a chain drive yet!
electronics are still being worked. servo will be an xpert 7000 waterproof high torque servo. powerplant may be a hobbywing or kinexsis waterproof brushless combo.
the one item I'm having trouble deciding on is the body. I want a truck body in the ballpark of a 12.5" wheelbase. I could extend the wheelbase if needed. I like the look of the proline topkick but not sold on it yet.
I'm still collecting parts but will post of pics of things as it comes together.
- stainless hardware everywhere possible
- no steel chassis (plastic and aluminum) with easy access for cleaning and no pockets that will build up mud
- easy to maintain axles with plentiful parts support
- transmission that is simply and as few moving parts as possible
- waterproof electronics that can handle splashes but have them mounted high in case I'm in deep water
