matzetf2
Hello Guys ,
I am Matthias 31years old from Germany , i am new to the RCCrawler and this will be the first Build thread .
I hope my englisch writing will be good enough so that all of you can understand it
I am a big Jeep fan , and this is not my first RC Jeep
So it will be a Jeep again , but this time a TJ .
First of all ther was the decision for the chassis , i am running already a few MST CMX chassis .
But this time i have choosen the RC4WD TF2 SWB chassis , because i was looking for some more scale detail ...
But on the other side the SWB is a leafspring chassis , and that dosen't matches the Jeep TJ becaus that model has a link setup .
So i had to convert it to a link setup with panhard .
First of all i startet with the mounting points for the links on the chassis , i had to fabricate some custom spacers and some braces to get a good suspension geometrie with no binding .
Then i started on the links , these are made out of M3 threaded Rod and carbon fiber pipes .
After i got those done and everything was working good i had to do the panhard setup too ...
Here i used again a self made brace to get the Panhard link mounted to the axle , on the chassis side i used a part of a RC4WD Gelande2 chassis .
Last but not least i made the BTA rod and steering rod ...
After everthing was working perfect , i started on the shocks . The base iss a SCX10 Shock but i modified it with losi springs and selfmade spring plates . I use this combo an a few rigs and it works perfect .
On my other rigs i use also a rubberband set up so i get the shocks to a semi drop setup ...
Later on i have changed the Yota2 rear axle to a RC4WD K44 axle , this will give me a slide underdrive and better performance !
Ok but now enough words , here are some pictures from the progress ...
Hope you enjoy it !
Hope you enjoy it !
