larger battery tray
xjman
In the basement
What are you guys using for lipo batteries that are too large for the stock battery tray. My 3s batteries are just a hair too long to fit. Should I just knock off one end, or is there a better option.
I use to use a gens ace 3s 5400mah battery that fit perfect and lasted 3+ hours, but I have since flipped the tranny and now use 2200mah 3s batteries that still last a good hour and a half. the battery in the scx10.2 is a hard decision imo as the battery is what's meant to give it its weight up front over the axle but it's also high so somewhat of a double edged sword, especially when stock. I ended up going with the smaller lighter batteries and adding weight to the front in other ways. smaller batteries are also cheaper.
I'm not too concerned about ultimate performance. This is more of a scale thing for me at this point. I've got a hardbody on the way that will go on this or on my trx4 depending on how i like the lexan body. If i don't it's going to go to the trx4 and the scx10 will get the hardbody. If I need any weight down low i can probably con my boss into letting me make some stuff on the side over a Sunday when the shop is closed.
I had to pickup a new steering servo as my last unused 7955 is doa so i just got a smaller battery. What's the advantage to rotating the transmission? Weight moving more forward, or just actually doesn't look like the transmission is in backwards?
