TKW75
I have finally found some time to work on my FJ40 leaf spring conversion for the RC4WD Gelande II. I started with a set of TF2 leafs and mounts/shackles and began planning from there. In the end I decided I really liked the look of a lifted FJ40 with 37-38" tires IRL, so I used a spring over axle configuration, placed the fixed leaf spring mount ahead of both axles and lengthened the wheel base a bit by moving the front axle forward and the rear axle rearward. This is a fairly common setup for the 1:1 Cruisers that are heavily modified, so I figured I would replicate it.
The results are almost exactly what I was after. The front is just about perfect while the rear gave me some fits and I had to disassemble/reassemble the frame about 3 or 4 times before I got it right. This only means that my next one will go much smoother. I fully expected the rear to be the easy part, but for some reason it was fighting me the whole way. Oh well, live and learn.
Right, so onto the pics. I am terrible at documenting anything I do (mostly because I have so little time to actually work on my RC's before I am interrupted by at least one of my 3 young sons) but at least I grabbed some after pics. And pay no attention to the loose wires, sideways leafs, etc. The truck is barely bolted together to test the fit/form/function of everything. I will fully disassemble and reassemble once everything is set.
Here is the look I am loosely modeling my Cruiser after, albeit with smaller tires as these appear to be 44" or so. But I really like the rear fenders being cut and the longer wheelbase.
Here is my GII FJ40 after the leaf spring swap, sitting on RC4WD Compass tires, which are 4.75" tall. The rear fenders obviously need to be cut, but I was planning on that all along. The front is just perfect though.
Here are a few shots of the leaf spring mounts and shackles for both front and rear. The rear shackles laid down quit a bit (lots of weight) and I may try some Revolver shackles to help out a bit.
After driving it around for a bit, I was shocked at how well the suspension seems to work, flexing perfectly with enough body lean to keep the weight planted. It is much more realistic than my TF2 kit, so I will most likely tear that one apart to see what’s up.
I am pretty sure I am using these jack stands wrong (there were no instructions... lol) but they illustrate the point. There is a ton of travel in this truck when fully loaded up with body, electronics and battery.
Obligatory flex shots...
I am very happy with the results thus far and will begin refining and adjusting the truck as I get further into completion. The list of items I need to take care of are as follows.
1. Axle degree shims to get the pinions pointed above level instead of toward the ground
2. Revolver shackles in the rear to help with the flat leafs/shackles
3. Chino and o-ring mod on the leafs
4. Replace lots of hardware with the proper length (many are currently 'just long enough')
and finally,
5. Cut those rear fenders
Thanks for looking.
and finally,
Thanks for looking.
