Leaf springs with revolver shackles
Clemsoncrawler
USA
Hey y’all. Put those revolver shackles on the front and rear of my TF2, it’s on yota axles, not the yota 2’s, with the red springs. On the first run the rear red springs warped, so I put the stock stifffer springs on and it’s worked. On run two, one of the revolver shackles just broke in half so I ordered a new set, but now the red springs are just bottomed out under normal weight. I’m gona put the stock springs on to see if this helps. Running 100mm shocks front and rear. Any suggestions besides the stiffer springs?
You can set up a link to prevent it but you need to either make or buy linked parts to make it work. This is what I did in my old swb.
A&M garage sells a nice anti wrap kit but it won't work with the shackles. https://aandmgarage.com/shop/ols/products/pre-order-round-2-rc4wd-tf2-anti-bar-rwb-and-lwb
I'm running the shackles and relovers with the standard leaf springs and they do pretty good. Over enough time I've only replaced the leaf on the front only once.
