looking for Redcat Camo parts
mtrucker
Augusta
Looking to buy rear upper links for a Red cat Camo X4 ,, prefer aftermarket,,aluminum cant seem to find them anywhere, would even buy used if I could find them
The only links I found made specifically for the camo are from Redcat. I understand losi rock rey links are very close (within a couple mm).
If you want the Redcat links, just keep an eye on their shop. They seem to get restocked somewhat frequently. Also order from teamredcatshop to save a few bucks compared to Redcat direct.
I bought some Aluminum losi links,, I have a couple of Rock reys also, they are close enough in length but there is a slight angle on the rearend housing end. I think there will be enough movement in the ball end so that it wont bind
I just ordered "Husky Links" off ebay in the 130mm length paired with the Traxxas angled rod ends = 150mm. These are M4 threaded stainless. I will post an update when they arrive and are installed. These should be slightly adjustable in length to get the pinion angle correct and inexpensive to replace rod ends if they break.
