Losi shock parts
dirttrackdemon93
Casper
I recently picked up a used MRC and it was setup droop. I need to know if anyone knows or has the part # for the losi threaded shock bottom spring cup?
Thanks !
Is the part that you looking for the one that screws into the bottom of the shock body? Or the ring that screws down the body of the shock?
on mine they were the same as the plastic stocks, a trick to keep them on is get a small piece of antenna tube, cut about 1/8 inch of it and heat up the tube and slide it over the shock shaft after removing the ball end thing and the spring. Once it cools down its very hard to move. Reinstall the ball end part and spring and slide on the spring cup, then push down the shock to fully compress it and it will slide the antenna piece and wedge it between the cup and ball end. It wont ever fall off and you can still take it apart.
I would post a pic but I dont run springs anymore
If your asking about the spring retainer on the bottom of the shocks I'm running RC18T retainers and they fit nice and snug around the rod end. The spring diameter is the same and they won't fall off if there is no tension on them. Plus your LHS should have them in a four pack. Hope that helps.
I only found 1 of 4 today but i will dig and find the others if you need them let me know and i will dig for the others and hopefully find them.
Cole
