Losi finally released a brushless system for the MRC and it's sensored! It will be interesting to see how they compare to the competition and to brushed motors.
Information from Losi.com
Features
Designed specifically for Sensored Brushless operation
Easy single-step setup
Features a pre-wired Losi Mini power connector
Throttle Limiting capability (Forward/Reverse)
Programmable via Quick Programming Card or PC software included
25A continuous current with 35A peak
Two-color LED to indicate functions
Adjustable low voltage cutoff to protect your investment
Optimized for spread spectrum or legacy radio systems
No-cogging sensor design
Compatible with most leading sensored electronic speed controls
18.5T Motor features a long-life neodymium sintered rotor for superior torque and stronger braking
Precision ball bearings for improved performance
Pre-wired with gold-plated bullet connectors
Minimal motor maintenance required
Technical Notes
ESC Specifications:
Type: Sensored Brushless Only
Forward: Yes
Reverse: Yes
Brake: Yes
Continuous Maximum Current: 25A
Input Voltage: 7.2-9.6V (NiMH 6- to 8-cells); LiPo 2-3S (7.4-11.1V)
Input Connector Types: Losi Mini style
Motor Limit: Most 380 or smaller sized sensored motors of 4.5T or higher
Momentary Peak Current: 35A
Dimensions (WxLxH): 1.0 x 1.7 x 0.6 in (26.1 x 44.5 x 16.5mm)
Weight: 1.1 oz (33 g)
BEC Voltage: 5.0V, 2A
PWM Frequency: Spread spectrum or legacy systems
Auto Cutoff: Programmable
Motor Specifications:
Bearings or Bushings: Precision Ball Bearings
Weight: 2.2 oz (63g)
Overall Diameter: 0.89 inches (22.5mm)
Shaft Diameter: 0.78 inches (2.00mm) with flat
Shaft Length: 0.40 inches (10.5mm)
Overall Length: 1.75 inches (44.5mm)
Rotor: Sintered neodymium
Connector: 3.5mm gold bullet
More info here:
http://www.rccaraction.com/ME2/dirm...0&tier=3&nid=100A27A33E964AEDA353AE15F8C23EF3
http://losi.com/Products/Features.aspx?ProdId=LOSB9567
They are releasing some aluminum parts for the Micro Rock Crawler as well.
Features
Technical Notes
ESC Specifications:
Forward: Yes
Reverse: Yes
Brake: Yes
More info here:
