machinest crew: slide tolerance?
STANG KILLA SS
~THE SCALE SHOP~
KILLEEN TX
say ive got a machined shaft thats 2.000" OD.
i need a sleeve/collar to slide over it(say .25" in "length"). a nice slide fit, not press, and not sloppy. ie good enough to keep the shaft and sleeve centerlines parrallel and not let the sleeve/collar turn sideways and wedge.
what should the ID of the sleeve be. ie a slide fit tolerance?
2 inch = 50.8mm
Precision Slide fit = Locational clearance fit provides snug fit for locating stationary parts; but can be freely assembled and disassembled.
Symbol of Fit = H7/h6
Maximum hole size = 50.830 mm
Minimum hole size = 50.800 mm
Maximum shaft size = 50.800 mm
Minimum shaft size = 50.781 mm
Note there is a possibility of having no clearance in this type of fit. That means no air gap between the shaft and sleeve if shaft OD is machined to 50.8mm and the hole bore also comes to 50.8mm. However depending on the final machined size there can be some air gap.
Maximum clearance = (50.830 - 50.781)
= 0.049 = 49 micron
That means there can be a maximum air gap of 24.5 micron between the shaft and the sleeve.
Close running fit
= Sliding fit not intended to run freely, but to move and turn freely and locate accurately.
Symbol of fit = H7/g6
Maximum shaft size = 50.790 mm
Minimum shaft size = 50.771 mm
Note the holes smallest diameter (50.800 mm )and the shafts maximum diameter (50.790 mm).
Clearance = 50.800 - 50.790 mm
= 0.010 mm = 10 micron
That means there will atlest be an air gap of 5 microns between the hole and shaft.
Maximum clearance = (50.830 - 50.771)
= 0.590 mm = 59 micron
Hence the maximum air gap can be 29.5 micron after machining.
I work in a tool and die shop and deal with slip-fits and press-fits every day. For your application, I would suggest between .0005"-.001" clearance. With your sleeve being only .25" long, any more clearance would allow it to rock quite a bit.
thanks hoosier!
I increased the sleeve length to .4" to help alignment. what could I increase the clearance too?
and is that calculated per side? or is that total difference in diameter
You may get away with a little more clearance but I wouldn't go over .002". That is total clearance (2.000" shaft OD/ 2.002" sleave ID)
