Mamba Monster X & Holmes PP 3500kv
OurJK
The Ocean State
Looking for a little help with my MMX and PP 3500. I am getting some cogging at start up and its hurting the crawablity of my rig. can someone suggest how to help fix this for smooth start up?
Something is definitely not right. I ran a PP 3500 and MMP and the startup was super smooth without any CastleLink adjustments. You could try resetting the MMX back to defaults and beyond that I would start to suspect one or more of the sensors in the motor. Any way you can test it on another ESC?
Re: Mamba Monster X & Holmes PP 3500kv
So I looked at things tonight, the sensor wire was not connected to the esc. I ordered the castle sensor harness for X esc's. Once I get it I'll see if that was the issue
Sent from my LG-H900 using Tapatalk
This will fix your issue for sure.. I have this EXACT combo in my top truck. Low speed technical crawling? sure.. 4S balls to the wall pulling? you got it..
I can't imagine this setup on 4s... I'm hopeful that the issue!!
