TrailDawg362
Brake line tubing is thin-walled mild steel, so it won't survive a 30 foot drop, but adding some "X" bracing should be rigid enough to withstand normal use. The silver solder joints are actually stronger than the tubing. If the joints holding are your concern, you should be fine. I'm fairly new to brazing, but from what I've seen the tubing will bend before the joints break.
T.D.
T.D.
