Mayhem Comp Wheels opinions.....
Pappy
Southwestern Pa.
I was looking at the comp wheels, and like them, but what is the pros and cons of the delrin vs. the aluminum wheel materials?
The aluminum are heavier and you can get all the annodized colors. The delrin are lighter and you can dye the white ones but not the black..."thumbsup"
Other than that they are basically the same......sturdy and easy to use.
If you don't pack the wheels full of bearings they both make a lil noise. I have a few sets of rolling weight Mayhems if you would like to check em out in person.
i love them, ive got 2 sets of black delrin and one set of aluminum. on my berg i run all 4 completely full with lead wraps added to the front. so you can't hear them at all. i love my mayhems!
I have one set of black delrin ones and four sets of aluminum ones and I hear the bearings a little but it doesn't bother me.
I like the aluminum ones for my rigs because I don't have to load the inside of the tire with weight since I can get enough with the bearings. I had to wrap 2 full strips of weights on the delrin ones to get them where I wanted them.
So in short go for the aluminum ones and never worry about it again.
While I've not heard of it being an issue I'm afraid to run the delrons due to the potential of threads loosening or stripping on the beadlocks.
As for MAyhems in general...they rock"thumbsup"
I've tried others and gotten rid of them and kept the Mayhems, and am currently waiting on another set to arrive :mrgreen:
While I've not heard of it being an issue I'm afraid to run the delrins due to the potential of threads loosening or stripping on the beadlocks.
As for Mayhems in general...they rock"thumbsup"
i prefer delrin because i don't have to worry about screws loosening up. ive noticed on aluminum wheels that in the first run on them i get a screw or two backing out. ive started using a small amount of blue loc-tite on them and its never been an issue since. the aluminum ones are nice because i only have to wrap one strip of lead around the fronts, whereas the delrin ones require much more.
While I'm afraid to run the delrons due to the potential of threads loosening or stripping on the beadlocks.
This is not a problem ,in fact I think the delrins ones hold screws better . But like with the Alum. ones you can over tighten them . "thumbsup"
Hey Ken, My delrin 7's are tough as hell! I can crank down on the screws hard enough to strip the head of the screws out before the delrin strips. They hold just fine.
I see they come with 7/16 bearings, but can accept up to 9/16 bearings.....Anyone doing this?
I thought the bearings that came with them were 9/16. I haven't done it yet but have been looking on the bay and they are pretty cheap to get. I will have to try them out and let everyone know.
So lets say I want wheels for my Berg, in the comp style......And I click order and see.....
[URL="http://www.mayhemengineering.com/index.html"]HOME
RIMS
__BERG RIMS
__1.9 RIMS
RINGS
COLORS
ORDER
CUSTOMER
PICS
[/URL]SPONSORED
RIGS
http://www.mayhemengineering.com/sponsored.html
Ordering Information
To place an order, email us at:
mayhem_eng@yahoo.com
Standard 2.2 Beadlocks from Mayhem Engineering
$95.00/set + $10.00 shipping with in the USA
A set is any 4 rims, either offset, with any 4 front rings and 4 traditional back rings, any anodized color combination – your choice (Mix & Match or all the same) hardware included. (Traditional ME-2008-8 back rings and stainless steal hardware are standard unless otherwise stated.)
Additional rings
$30.00 / 4 rings
$45.00 / 8 rings
Engraving $20.00 (within reason). Engraving on Competition Rings only.
We offer two different offsets in our standard 2.2 style rims.
1st Offset - .443 (11.25mm) this is a negative offset, meaning that the bottom of the hex is as close to the hub side as possible. (see Diagram A) This offset offers a wider track width. Original offset – Wide.
2nd Offset – Our latest design - This offset is .147 (3.7mm) this is also a negative offset. This offset will bring your wheels closer to the frame, this offers a narrower track width of approximately 10 ¼”. New offset – Narrow.
We offer both the Wide and Narrow offsets in all of our wheel designs:
2.2 Mayhem “Spider Wide” ME-1001-W
2.2 Mayhem “Spider Narrow” ME-1001-N
2.2 Mayhem “7 Wide” ME-1002-W
2.2 Mayhem “7 Narrow” ME-1002-N
2.2 Mayhem “Phatty Wide” ME-1003-W
2.2 Mayhem “Phatty Narrow” ME-1003-N
We have nine ring styles:
2.2 Mayhem “Grinder” ME - 2001
2.2 Mayhem “Custom” ME – 2002 (Front or Back Ring)
2.2 Mayhem “5 Point” ME - 2003
2.2 Mayhem “Competition 8” ME – 2004-8 (can be engraved for an add’l fee)
2.2 Mayhem “Competition 16” ME – 2004-16 (can be engraved for an add’l fee)
2.2 Mayhem “Nuke” ME - 2005
2.2 Mayhem “Nuke Plus” ME - 2006
2.2 Mayhem “Nuke Round” ME - 2007
2.2 Mayhem “Traditional” ME – 2008-8 (Front or Back Ring)
2.2 Mayhem “Traditional” ME – 2008-16 (Front or Back Ring)
We offer five anodize colors plus Machine Finish (aluminum)
Blue Red Gold Black
Violet (special order) Green (special order)
Diagram A
Competition Double Phatty
$130.00 shipped within the USA
Part Number ME-1004-Comp (specify aluminum or Delrin)
Rims available in Aluminum or Delrin
The benefits of this design:
Need only remove outside locking ring to adjust weight
No need to remove the tire, saving time
Adjust weight by adding or subtracting 9/16" ball bearings or stationary weights (stationary weights not provided)
Just about any type of wheel weights (other than bearings) can be used
Ball bearings will always stay at the bottom of the wheel to keep center of gravity at its lowest point
Largest ball bearing 9/16" or smaller can be used
The key to this design using any type of ball bearings is to KEEP them below center line of the wheel; if above center line it will not work as intended. If you are above center line the bearings have a tendency to flop over the top and lose the benefit of keeping the center of gravity at its lowest point
This design doesn't add a lot of weight, but what weight is there keeps the center of gravity at its most useful point (low in the wheel)
A Set Includes:
Four (4) Mayhem 2.2 Competition Double Phatty Rims – Machine Finish or Delrin
Four (4) Traditional rings - your choice of color (red, blue, gold, black or machine finish, violet and green are special order)
Four (4) Competition 16 Rings - your choice of color (red, blue, gold, black or machine finish) - your choice of 8 or 16 mounting holes
Sixteen (16) 9/16" dia. steel ball bearings
128 stainless steel button head screws
Plus engraving (within reason) on any anodized color (machine finish would be hard to see).
Shipping included within the USA (outside of USA contact us for quote)
Pre-orders being accepted now. Lifetime replacement warranty, excluding anodize and hardware.
Now I am totally confused.:?:?:?
