Correct me if I'm wrong, but I get 6.64:1 for an internal trans ration for the MRC. 16t top shaft into 34t idler equals 2.125:1. 16t secondary idler into 50t main gear is 3.125:1. 3.125Ă—2.125=6.64:1. I'm not trying to nitpick, I need this info myself as well. Working on a t-case setup with existing parts. I'm almost there now.
Sent from my SCH-I535
you could be right, as i said, i dont know the ratios, or if the numbers are correct, i just used numbers i sourced online.
EDIT
I cant find anything to verify the tooth counts on the gears, but if your teeth counts are correct, then you're right on the numbers, i'll pull my spare trans apart later and verify..
EDIT again
I'll also see if i can verify the numbers for the Merv Trans
Another EDIT
I have not been able to verify the MRC trans gear tooth count, but assuming your numbers are correct, and based on my math (which could very well be wrong), the Merv trans is not nearly as close as i thought it would be, looks like it's
Flipped Gears - (25/18.)*(35/13)=3.74
Stock - (18/25)*(35/13)= 1.94
MRC is
(34/16)*(50/16)=6.64
So the MRC Trans is considerably slower than the merv, even flipped, However, that said, i have been able to fit a 66t spur on the merv, and could likely gear it down to a 9t pinion with that big spur, so i could be at:
Merv- 66/9=7.3333*3.74=27.426
Compared to a stock MRC (i think the stock pinion is 14t?)
MRC- 14/60=4.285*6.64=28.4521
MRC 12t?- 12/60=5*6.64=33.2
(edited to correct math)
So the MERV ends up being similar with the ability to put on the 66t spur, i think i have seen a mod for the MRC trans to fit a 66t spur, so they would be comparable with gearing in the end, both very adjustable with the options for pinion and spur, just hoping the MERV trans is more durable, i have run my MERV with a 5700kv 550 can brushless motor on 3&4s doing standing backflips, doubles and triples off a parking block or curb, so i am confident in the transmission's strength..
