Motor Choices/Motor Uses
fuyutime2
My House
The last thread was pretty messed up after a change of ideas, and so we have the new motor thread. I wanted to find a thread with what motors are reliable and such and since there wasn't one, I made one. Also, please make sure that the motors you post are for ROCK CRAWLING and not short course or somthing else. unless by popular demand. The new list. These are in alphabetical order. And also, some motors will have * and **, etc. at the bottom of this post there will be a guide. ALL PRICES ARE IN USD!!!! Note: these motors are for 1/10 Applications. It will stay that way for now until I get some time to do 1/18 Motors.
The Brushed Crawler Motors:
Axial AM27 540 Electric Motor-$13.99
Axial 55T Electric Motor-$16.79
Axiom 65T Handwound-$28.95
Axiom 86T Handwound-$28.95
Holmes 5-Pole Brushed Motor-$6.00
Holmes Cobalt Puller 500-$49.99*
Holmes Cobalt Puller 7T-$79.99*
Holmes Cobalt Puller10T-$79.99*
Holmes Torquemaster Pro Handwound-$55.99
Holmes Torquemaster Pro Handwound Yokomo-$47.99
HPI Racing Saturn 27T Motor-$13.99
Integy Pro Lathe Motor 35T/45T/55T/65T/85T Single-$19.99
Integy V10 Matrix Rock Crawler Professional 50S/55S/60S/65S/70S/75S/80S/85S Motor-$31.99
Integy V11 Rock Crawler Professional Motor 35T/45T/55T/65T/75T/85T-$31.99
JP Warrior Chrome 35T-$55.99
JP Warrior-LE 35T Double (Pair)-$125.98
JP Warrior-OG 50T-65T High Turned-$54.99
JP Warrior-R/T 35T-$58.99
JP Warrior-R/T 40T-$58.99
JP Warrior II 45T-$69.99
JP Warrior-R 35T-$69.99
JP Warrior-R 45T-$52.99
JP Warrior-Max 50T-$55.99
JP Warrior-Max 55T-$59.99
Losi Comp Crawler Motor-$22.99
Losi Night Crawler Motor-$21.79
Novak Forty-Five 45T Motor-$26.99
Novak Fifty-Five 55T Motor-$26.99
Novak Terra Claw 55T Motor-$16.69
Tekin Rock Crawler 55T Motor-$29.99
Tekin Rock Crawler 55T Hand-Wound Motor-$53.99
Trinity 55T Rock Crawler Motor-$39.99
Venom Fireball Rock Crawler 50T/55T/60T Motor-$17.59
The Brushless Crawler Motors: Brushless Motors require a special esc that will run the motors:
Associated Crawler 21.5T Brushless Motor-$59.99
LRP Crawler 21.5T Brushless Motor-$69.99
Novak Crawler 18.5T Sintered Brushless Motor-$79.99
Novak Crawler 21.5T Brushless Motor-$79.99
Novak Ballistic Crawler 18.5T Brushless Motor-$89.99
Novak Ballistic Crawler 21.5T Brushless Motor-$89.99
*These motors require a spceial speel controller due to its low number of turns. The 10T puller can be used with a Tazer 10T esc.
That's all for now, I'll post more up tomorrow. Thanks for looking and rate it 5Stars!
Motor Usage: Higher turn motors are typically used in competition crawlers due to their high amount of torque and control. With these motors, you can probably crawl a 75* slope and still go on to the next round. Lower turn motors are typically used in scale crawlers and pullersare the motor of choice for scale crawlers. Pullers have very low amount of turns, usually lower than a typical race motor. These scale motors are used for a good amount of torque and medium speeds. A 3s LiPo is usually used with lower turn motors to help top speed.
Lower Turn Motors: These motors are typically used for scale crawlers that need torque and speed. These motors range from 7-10T Pullers to 27-45T Motors. Thesse can be used for competition crawlers, but will often be too fast and will lose you more points than it helps.
Higher Turn Motors: These motors are usually used in comp crawler becuase of their higher amount of torque. These motors range from 45T-85T motors. These could be used for scale crawlers, but it will be slow and may not fit the criterion of the competition you may be in.
