Motor for my next project
greengoblin
columbus
Ok im about to start 2 new projects trucks. So lets see what motor and esc you guys and gals like. Keep in mind that i would like to use the same motor and esc for both trucks.
Truck 1 will be a dually 4x4.
Truck 2 will be a mud bog truck.
Motors and esc im looking at are.
Motor and Esc#1 Hpi flux blur
Esc
Specs:
25.2V maximum with Flux Tork 2200Kv brushless motor
16.8V maximum with Flux Tork 2650Kv brushless motor
Sensorless technology eliminates additional sensor wiring and complexity
Cells: 6s LiPo
Continuous: 120A*
Resistance: 0.0003 ohms per phase
Brake: Proportional with adjustable curve
Reversible: Yes - with lockout
Low Voltage Cutoff: Programmable
Size: 2.2" x 1.9" x 1.4"
Weight w/wires: 121g (4.26 oz)
Connector: 6.5mm bullet
Flux motor
Specifications:
Max Input Volts: 25.2
Amp Rating: 120
Weight: 424g (15 oz)
Motor Diameter: 39.98mm & 41.78mm with fins
Motor Length: 75.18mm
Shaft: 5mm
Bearings: Oversize ABEC-1 front and rear
Connector: 6.5mm
Motor and esc #2 Mamba Monster 2
Esc
Specifications:
Input voltage: MIN: 2s LiPo; MAX: 6s LiPo
Max continuous amperage: 120A (full throttle continuous operation with cooling airflow)
BEC specifications: User selectable output between 5 and 7 volts
Operating environment: Waterproof* design allows for use in nearly any environment.
Brake: Proportional
Size (LxWxH): 1.86x2.19x1.33" (47x56x34mm)
Weight (without battery connector soldered to ESC): 3.93 oz (111.5 g)
Motor#2 Mamba Monster 2
Motor Specifications:
Castle 2650kv
Max Input Volts: 16.8
Amp Rating*: 120
Weight: 370g (13.1 oz)
Motor Diameter: 39.98mm - 41.78mm with fins
Motor Length: 68mm
Shaft: 5mm
Connector: 6.5mm
Note: Motor wires OK to shorten
*Full throttle continuous operation with cooling airflow
Motor and esc #3 tekin Rx8 / Redline t8
Esc
RX8 Specifications
Controls: Forward/Brake/Reverse
Input Voltage: up to 6S Lipo
Continuous Current: 210 Amps*
BEC: 6.0V/5.0A
Motor Limit Brushless Mode: No Limit
Motor Limit Brushed Fwd Only Mode: No Limit
Motor Limit Brushed Fwd/Rev Mode: No Limit
Throttle Profiles: 7 choices (on board)
Brushed Modes: Fwd Only, Fwd/Rev, Rev Delay
Brushless Modes: Fwd Only, Fwd/Rev, Rev Delay
Dimensions: 1.5 x 2.2 x 1.4"
Weight Approx: 2.7oz
Motor
T8 Specifications:
KV Rating: 2650
Weight: 11.5oz (341g)
Shaft Dimensions: 19 x 5mm w/flat
Motor Diameter: 1.57” (40mm) / 1.65” (42mm) including fin
Motor Length: 2.80” (71mm)
Bearing Dimensions: Front: 5x16x5mm / Rear 5x11x5mm
Personally I would run a tekin rx8 esc and your choice of remain motor. The rx8 can handle just about anything you throw at it and it has a lot of tuning options
I have the rx8/T-8 combo. Had it in a slash 4x4. Broke diffs left and right on 3s. And no I wasn't bashing it too much they would sometimes break going down my street! My buddy had a mamba monster 2650 and broke nothing. Plus the tekin is sensored. That right there is worth it.
