valheru
I need a brushed motor recommendation for a heavy Boom Racing D90 scaler (same transmission, t-case and axle gear ratios as the Gelande 2):
Weight (incl. battery): 13.5 lbs
Current gearing: 11/87 (48p)
Voltage: 3S
ESC: Tekin FXR
Tires: 1.9" x 4.19"
Operating conditions: Trail/Recon G6
I am currently running a Traxxas 550 21T with 11/87 gearing which is the smallest pinion I can go with this setup:
- The speed is ok;
- I need more torque; and
- Lower running temperature as this setup runs hotter than I like them to (nothing close to where damage can occur).
I already tried the following RC4WD 540 brushed motors with no improvement compared to my current setup: 35T, 45T and 55T.
Thank you
D 8)
Voltage: 3S
ESC: Tekin FXR
Tires: 1.9" x 4.19"
- The speed is ok;
Thank you
D 8)
