Motoworx 2.2 HD 6 Spoke
motoworx
Canon City
New March of 2017 the 2.2 HD 6 Spoke wheel
Whats New:
HD style wheels have the 12mm hex machined into the back, no additional mounting hub is needed for the HD style wheel
2mm hardware is used throughout eliminating the need for two different hex wrenches between the rings and center-cap
The outer ring hole pattern is 16, inner ring pattern is 8 hole.
Excess material has been machined out on side walls on the inboard wheel walls for weight savings without structural compromise
Sold Individually. Be sure to add the desired quantity to your cart.
-2mm beadlock ring screws included
-2mm center cap screws included
-The inner ring is included with each individual wheel purchased.
-The desired outer ring must be purchased separately in the RC Bead lock Rings section of the website.
-A 16 HOLE RING or 8 HOLE RING can be used on the outer surface.
-Motoworx HD centercaps are not included. Please choose between these or scale hubs in wheel accessories.
Specs
Backspacing .450″ to bottom of hex
Wheel width (w/o rings)1.1″
Fully assembled weight 5 oz.
12mm hex
Re: Motoworx 2.2 HD 6 Hole
It's great to see a new design from you. I can vouch for your wheels - they are top of the line and nobody beats your finish and quality.
Super clean wheels! I just got my first set from you recently and it looks like a second may be in my near future. "thumbsup"
