moving battery to front axle?
Battery
Jut remove the battery tray from the rear. Use the supplied spacers and pull the front 2 screws out of the electronics box. Its pretty easy once you do that. Good luck.
Directly out of the manual that every Scx10 came with.
The only thing is that it can be a bitch to try to get the long screw through the front of the brace because the hole isn't tapped yet and it's a fine threaded screw.
