My 2010
vodka child
England & SoFlo
Specs:
YTC BJv3 chassis with updated battery/skid plate
JP Customers upper links and front lower links (front lowers heated and bent to clear the gear case, plus ground down to aid ground clearance and reduce weight)
T1E Moon Buggy rear lower links
RC4WD Bullly light weight axles
- Front with R7R servo mount & high clearance steering solution and RC4WD heavy duty XVD v6, shaved steering knuckles for better steering lock
- Rear with Chaotic Crawler Delrin rear Bully tubes
Front wheels - VP DH Comp wheels with 2 weights/*Mayhem Doubble Phatty Comps
Rear wheels – VP SLW v3s 0.7 with a 600 hub/*VP SLW v3s 1.0
Rover white dot tyres/*Boss Claws
Losi 4” shocks with gold springs and internally limited by 8mm (40 weight Losi shock oil)
Holmes Hobbies TorqueMaster BR-XL ESC
Holmes Hobbies TorqueMaster Pro Handwound 45t x2
Punk RC DIG unit
HiTech Servo
KrawlerKonceptz skins (Tamiya Sand Scorcher doppelganger :D) and scale license plate
* second wheel/tyre combo that I have.
I like it... Looks like it's going to be a threat at the Comps... Nice Combo of parts.
Thanks! "thumbsup" taken a while to get the bits together and only posted up the build now i've manged to get all the stuff together, allowing me to tear the rig down and rebuild with everything ready.
The weight difference between things like the delrin rear axles tubes and the high clearance steering solution is pretty amazing
RC4WD lightweight Bully rear axle tube:
Delrin replacement
Pretty much half the weight. The rig is now a gnats cock over 6lbs
sorry- should of checked some more on Losi "Gold Springs" before I posted-
insane rig BTW. love the build.
