Dime a dozen, I know, but thought I'd post it now that its close to getting done.
GC3-A chassis
AX-10 axles with Gunnar toobs
CKRC's BLACK Low Profile Ax10 straight axle kit (don't seem to be selling these anymore)
Axial CVD Kit Set For The AX10 #AX30464
Unknown aluminum C hubs
Vanquish Zero Ackerman High Steering Axles (http://www.vanquishproducts.com/vp-high-steering-knuckles-zero-ackermann.html)
Over/Under gearing
Axial Heavy Duty Bevel Gear Set - 43T/13T #AX30402
Axial Heavy Duty Bevel Gear Set 36T/14T #AX30401
Fast Lane Machine Diff Locker (http://www.fastlanemachine.net/proddetail.php?prod=FLM75100&cat=24) #FLM75100
Fast Lane Machine Outdrive Gear (http://www.fastlanemachine.net/proddetail.php?prod=flm75200&cat=24) #FLM75200
Axial Comp Shocks, long rod end, 30wt oil, medium piston and red springs #AX30092
MIP drive shaft #08101
CKRC Aluminum Servo Protector (http://www.ckrccrawlers.com/ckrc-aluminum-servo-protector-for-all-110-servos-p-3045.html)
CKRC Aluminum Servo Mounts (http://www.ckrccrawlers.com/ckrc-black-aluminum-servo-mounts-p-921.html)
JR DS8711 Servo (digital, but not high voltage with 403oz of torque at 6V)
Axial Beadlock Wheels
HotBodies Rovers
Pro-line Crowd Pleazer RC Clear Body
Mamba Max Pro ESC
Spektrum SR3001 receiver
Elite 1300 11.1V 35C Lipo Pack (http://cheapbatterypacks.com/?apage=prodpage.asp&invid=EL130035C3S&sid=825873&bc_menuid)
Motor?!?! The 55t brushed on doesn't seem to either work or doesn't work with the Mamba Max Pro (yes I do have it setup for brushed). Have a 'bash' 21.5t brushless motor coming, but am not sure about what brushed motor I want to get; probably a 35t Holmes.
I was going for more of an 'old school' paintjob, but the teal I used didn't turn out quite as dark as I was planning.
Another view of the body.
Isometric shot of the rig. I'm running some lexan trays, cut from 0.060 lexan, to mount my electronics on (receiver and esc) in the rear and battery in the front. I may fab up a large aluminum front plate to hold the battery using the GC3A plate as a guide, we'll see.
Top of the rig.
Bottom of the rig.
Side of the rig.
GC3-A chassis
Over/Under gearing
HotBodies Rovers
Mamba Max Pro ESC
Top of the rig.
Bottom of the rig.
Side of the rig.
