Highmark
Test bed:
The "Ubber mule" running TLT axles and a stampede tranny with a 87t spor and 11t pinion gear.
Test Place
Green River in Rochester Kentucky, consists of sandrock,smooth river rock and some other various smooth stones.
Lathe
I gotta say, I am not fond in the least of this motor. It gives you the feeling of driveing on a dead battery throughout the run. The low RPM's are the main reason behind this. It does however get killer runtimes (I ran for the better part of the day on a GP3300 pack) and makes almost no noise. It is also shorter then a normal 540can motor so it would be perfect for say a clod if you didnt want to run 9t pinions. If I owned a clod or a pajero I would recomend one but for most shaftys where gear reduction isnt a problem and you can have RPM and tourqe I wouldn't run one.
Mag Mayhem
A good over all motor, gives out plenty of power and pretty decent runtimes. It is very dependable and cheap. I really dont recomend it for clods with tight link set-ups because the can is longer then a 540 motor but it is very effective in most situations. If you can't decide on what motor meats your needs try this or.....
Multiplex 600
It's 9 bucks! And it throughs out some killer power on 12 cells (Brad striped out the out drives on his pede in 3 minutes at green river) and does pretty well on 6. Proforms a bit like a mag mayhem but not.I dont have alot of time on this motor so the best thing I can recomend is that you buy it-I mean think about it, 9 bucks 8O
Hope that helps out with the hole "wut motor" question.
Test Place
Lathe
Mag Mayhem
Multiplex 600
