ADDED DIG SET-UP WITH PICS & DIRECTIONS. This is my SW3 with it's 1st Bug Body. I haven't painted a lexan body in about 15 years, wow that's a long time, and it shows. I used rattle can and stencils for the graphics. I was a bit disappointed that the stencils didn't stick very well in the creases and bleed a lot, which caused problems with the clarity of the lines. I also didn't get it done in a day so the paint dried to much, which caused my base paint to peel when I tried to remove the stencils, so I had to cut with an exacto around all the stencils before trying to remove them (big pain in the butt). I tried my best, for such a long layoff, not to bad. Next time I hope to have an airbrush, which will be fun to experiment with. The masks are still on the windows, that's why it's white, and I need to throw some stickers on it. I'll try to post some more pics when I'm done.
I also included some pictures of my new link set-up which I bogarted from the GC-1, (Thanks Austin) for showing that set-up. I was needing a more neutral setting because I wanted less anti-squat and this seemed to fit the bill, triangulating the lowers and making the uppers a straight shot. I have a hyperion 3s Lipo that is skinny and tall which fits right in between the front upper links. I want to make a flat upper servo and battery mount so I can put the servo off to the side and keep the battery low in the center still. It will be tough to come up with something that won't interfere with the upper link mounts though.
I did come up with this before our summer finals event Oct 28th. I hadn't seen Cars69 thread yet, which his looks very good also. This is just a little different so it might help others who have a similar set-up. The rig handled very well at the comp, the flex is real smooth and getting rid of a lot of the anti squat helped it to not flip backward on steep inclines when you need to power up and over. I need to run it some more and tech some more to get everything out of it I can.
Sorry about the pics not being top notch, my camera is not the best.
Hope you like it, Stewie
