I am in process of building my budget WK crawler. Here are some specs and pics:
Wheely king, new 3 weeks ago
Stretched to 11.25" wheelbase with traxxis rod ends mounted to 1/4" steel rod drilled and tapped with 6-32 bolt inserts-used 1" bolts and cut the heads off, traxxis driveshafts mounted to stock WK u joints: cost= $8 for the rod ends, $8 for the shafts, rest free
Stock servo relocated to front axle with a 3/32" stainless plate of my own design. Servo linkage from same pack of traxxis ends and a piece od 6-32 allthread with a blue plastic tubing sleeve over it.Also the plate has just over an ounce of flat tire weights bolted to it: cost= $1.50 for a 3' piece of alltrhead, had the rest of laying around
Stock motor, geared to 15/ 96: $7
Tires cut with dremel, 2oz stick on weight in both front rims, Body cut with scissors, diffs JB welded, rear sway bar removed, spring spacers removed: all free
That is all I can think of right now.
I do plan on changing up the axle mounts and bringing the wheelbase to 12.25" and upgrading the stock motor and servo
Pics are of the WK on a crap boddied stampede.
