Vitamin J
Ok guys, i've got a new RTR, out of the box, the steering and throttle is all backwards.
I've got the steering issue fixed, with the switch in Normal, it steers left and right as it should, but when I pull the trigger, it goes in reverse, and vice versa...when I put the switch into REVERSE, it doesn't do anything.
So to make it go forward, I have to push the trigger forward, and pull to go reverse....also, when I go in reverse, and let off, it stops on a dime....when going forward and i lt off, it rolls to a stop.
I tried to rebind it and as far as the LED on the RX, it says that it is good. But still does the same thing.
