Need some ideas for my Wraith
SCALER14
Chapel Hill, Tennessee
I have a Wraith with upgraded aluminum steering links, front steering knuckles, aluminum lower links, and aluminum rear lockouts. My question is if you guys could maybe give me the top 3 upgrades yall have done to yalls Wraiths. Thanks guys I'm 14 with not a lot of money so the higher end stuff like motors and esc's are not on my idea list so mostly aluminum upgrades.
Driveshafts and some beef tubes will help. I haven't had much luck with the m3 rod ends but if they're working for now go with it.
Drive it and fix what breaks, doesn't need to get you to work err school "thumbsup"
If your using the stock motor and esc.You need to change that gearing or your gonna fry the motor quick.A spur and pinion are cheap. I ran 84 tooth spur and a 16 tooth pinion for a while on the stock motor.It did fine until I upgraded it.
Was that a lot slower than the stock gearing? Where did you get the gears and what was the cost?
Yes it's slower then stock but it will have more torque.I got mine at my LHS.But you can order them just about anywhere. just make sure they're both 48 pitch. They cost less then $15.00 for both. I say $15 but it's really more like $10-12.I used Traxxas ones because my hobby shop I go to had them on the wall.
