So I've got this super I built, and ever since its been able to move under its own power I've been trying to tune out the torque twist. Short links, long links, mounted low, mounted high, seperated and closer together, I've tried it all with various results.
I'm posting some pics in hopes that someone will be able to point me in the right direction.
The only way its been cured was to run it full droop, which is fine, except that I really need some belly clearance to get around most of the terrain around here. Too many sharp pointy rocks to have a belly scraper.
Front shocks are currently running 1/2 droop (springs inside and out), rears are full sprung, lots of preload on the rt rear. Shock oil is 40wt with a touch of 10k diff fluid. Springs are of unknown origin, but are the stiffest I have.
I've seen and downloaded the 4 link calculator, but was unable to get it to work right.
On to the pics...
On to the pics...
